[geos-devel] TopologyException: found non-noded intersection
G. Allegri giohappy at gmail.com
Fri Jun 25 08:14:51 EDT 2010
Here is a testcase which reproduces the exception:
http://www.giovanniallegri.it/share/selezione_exp1_red2.sql
Me and strk are trying to get into the problem... If someone else
(Martin) could give it a try...
giovanni
2010/6/25 G. Allegri <giohappy at gmail.com>:
> Actually this selection works. We're selecting more precisely the
> geometries that give problems.
> giovanni
> 2010/6/25 strk <strk at keybit.net>:
>> On Tue, Jun 22, 2010 at 08:58:24AM -0700, Martin Davis wrote:
>>> By the way, I tried the sample dataset you posted here in JTS 1.12 (alpha):
>>> http://www.giovanniallegri.it/share/postgis_selection.zip
>>> and it processes fine.  Actually it also works fine in JTS 1.11 (before the
>>> bug fix I mentioned).
>> Tried with GEOS trunk too, and works as well.
>> We need another selection ...
>> --strk;
>>  ()   Free GIS & Flash consultant/developer
>>  /\   http://strk.keybit.net/services.html
