[geos-devel] [GEOS] #358: Exception on Union
geos-trac at osgeo.org
Fri Jun 25 09:46:37 EDT 2010
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
The attached SQL file contains two valid geometries (a and b)
that, when unioned, result in a topology exception.
It is interesting that the CommonBitsRemover heuristic succeeds
in obtaining a valid union with bits removed, but results in
the output getting invalid again when re-adding the common bits !!
Ticket URL: <http://trac.osgeo.org/geos/ticket/358>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
