[geos-devel] Re: [GEOS] #358: Invalid output from Union (was:
Exception on Union)
geos-trac at osgeo.org
Sat Jun 26 19:09:28 EDT 2010
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Comment(by strk):
Sorry, the summary was wrong, problem is not a topology exception here,
but an invalid result. A topology exception might come up later, when
iteratively applying the BinaryOp.
The invalidity is a "Too few points in ring" kind. Basically when
translated toward origin (common bits removed) the code doesn't find
repeated points, but after re-translating up, for some reason, two points
become the same point (precision loss, I guess?).
If theoretically confirmed, this might mean applying common bits removal
might not
be a good idea from within the SnappingOverlay OP
Ticket URL: <http://trac.osgeo.org/geos/ticket/358#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
