[geos-devel] CascadedPolygonUnion XML testing
strk
strk at keybit.net
Sat Jun 26 19:16:46 EDT 2010
35 points version (2 geoms):
http://strk.keybit.net/tmp/another_dump2.sql
... still finds non-noded intersections ...
--strk;
On Sun, Jun 27, 2010 at 12:18:22AM +0200, G. Allegri wrote:
> I'm getting mad. The same geometries, run in a basic test written by
> me works fine: http://www.giovanniallegri.it/share/test_wkt.java
> The same geometries give errors in Postgis (+GEOS?) and with TestRunner...
> giovanni
> 2010/6/26 strk <strk at keybit.net>:
> > On Sat, Jun 26, 2010 at 12:26:11AM +0200, G. Allegri wrote:
> >> Before going to bed... a snapshot of the location causing the
> >> exception: http://www.giovanniallegri.it/share/error_condition_snapshot.png
> > Just in case mine is smaller, another reduction here:
> > http://strk.keybit.net/tmp/another_dump1.sql
> > (201 points in 3 geoms)
> > NOTE: my version is a database dump, failure happens on st_union
> > which fails with original geoms and fails with snapped overlay.
> > dropping any of the 3 geoms makes the operation succeed, haven't
> > checked if that's a special handling within postgis.
> > It'd be worth filing a ticket on trac for better handling.
> > --strk;
> >> 2010/6/25 G. Allegri <giohappy at gmail.com>:
> >> > This is the reduced version of the test xml:
> >> > http://www.giovanniallegri.it/share/TestUnionMultiPolygon_red.xml
> >> > Now it contains only two geometries. It tries to node them but fails,
> >> > so a second try is done with the SnapOverlay, but it fails too.
> >> > I don't know the algorithm so I'm not able, yet, to say what is failing.
> >> > giovanni
> >> >> Here is a test xml:
> >> >> http://www.giovanniallegri.it/share/TestUnionMultiPolygon.xml
> >> >> It's big, but I will reduce it nex time :)
> >> >> Notes:
> >> >> 1 - this multipolygon comes from an st_collect on 95 rows in a postgis
> >> >> table. The test on it fails with Topology Expection found non-noded
> >> >> intersection, because the MP is invalid. I've tested it on jts from
> >> >> trunk.
> >> >> 2 - I've run a cascadedunion.union operation on a List of the same
> >> >> geometries (picked with Geotools directly from the DB). It works fine.
> >> >> In this test I've used jts 1.10 shipped with Geotools. I will try it
> >> >> agains the trunk version as soon as possible.
> >> >> Giovanni
> >> >> 2010/6/25 strk <strk at keybit.net>:
> >> >>> On Fri, Jun 25, 2010 at 04:39:17PM +0200, strk wrote:
> >> >>>> Martin, is there any support for testing CascadedUnion
> >> >>>> with the XML format ? Would help comparing GEOS/JTS.
> >> >>> I've found TestUnaryUnion.xml in JTS repository.
> >> >>> I guess that's what GEOS should be using
> >> >>> for testing CascadedPolygonUnion.
> >> >>> Only need to actually port UnaryUnion ...
> >> >>> --strk;
> >> >>> () Free GIS & Flash consultant/developer
> >> >>> /\ http://strk.keybit.net/services.html
> >> >>> _______________________________________________
> >> >>> geos-devel mailing list
> >> >>> geos-devel at lists.osgeo.org
> >> >>> http://lists.osgeo.org/mailman/listinfo/geos-devel
