[geos-devel] Re: CascadedPolygonUnion XML testing
Martin Davis
mbdavis at refractions.net
Mon Jun 28 11:54:50 EDT 2010
As you saw, CascadedUnion is tested indirectly via the UnaryUnion tests.
Warning - those tests are just a small set of sanity tests. They don't
really stress the algorithm!
strk wrote:
> Martin, is there any support for testing CascadedUnion
> with the XML format ? Would help comparing GEOS/JTS.
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
