[geos-devel] [GEOS] #334: README file could be a bit more modern
and consistent
geos-trac at osgeo.org
Fri Mar 5 19:51:30 EST 2010
#334: README file could be a bit more modern and consistent
Reporter: mwtoews | Owner: geos-devel at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone:
Component: Default | Version: 3.0.3
Severity: Unassigned | Keywords:
The README file is starting to look a bit dated, since it doesn't include
build instructions with CMake. It also has a mixture of tab indents,
2-space and 4-space indents.
I've gone through and quickly updated a few things:
* all two-space indents (because they are small)
* removed the "#" command prompt, since this is a comment to some shells,
and I've added a few comments inline
* wrapped a few lines to a 80-character wide terminal
Please edit the attached patch as necessary.
Ticket URL: <http://trac.osgeo.org/geos/ticket/334>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
