[geos-devel] Re: [GEOS] #334: README file could be a bit more
modern and consistent
geos-trac at osgeo.org
Sun Mar 7 06:39:50 EST 2010
#334: README file could be a bit more modern and consistent
Reporter: mwtoews | Owner: geos-devel at lists.osgeo.org
Type: enhancement | Status: closed
Priority: minor | Milestone:
Component: Default | Version: 3.0.3
Severity: Unassigned | Resolution: fixed
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
Applied a slightly modified version (autotools also allows to build in
separate tree).
Committed as r2935.
Ticket URL: <http://trac.osgeo.org/geos/ticket/334#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
