[geos-devel] [GEOS] #336: Create union Fails
GEOS geos-trac at osgeo.org
Wed Mar 31 15:19:07 EDT 2010
 Reporter:  PeteS       |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  trivial     |   Milestone:
Component:  Default     |     Version:  3.2.0
 Severity:  Unassigned  |    Keywords:
 I'm most likely doing something stupid. I'm trying to create a simple
 union between two polygons...
 I'm using version 3.2
 GEOSContextHandle_t handle = initGEOS_r( exception_handler,
 exception_handler);
 GEOSGeometry * poly1 = GEOSGeometryFromWKT_r (handle, "POLYGON((0 1,0 8,1
 8,1 1,0 1))");
 GEOSGeometry * poly2 = GEOSGeometryFromWKT_r (handle, "POLYGON((0 0,0 1,8
 1,8 0,0 0))");
 GEOSGeometry * poly2 = GEOSUnion_r(handle,poly1,poly2);
 I get "assertion failed: intSegs.size() == 4, file
 FastNodingValidator.cpp, line 60"
 What am I doing wrong?
Ticket URL: <http://trac.osgeo.org/geos/ticket/336>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
