[geos-devel] use of STRtree functions in C API
Roger Bivand Roger.Bivand at nhh.no
Tue May 4 10:26:50 EDT 2010
On Tue, 4 May 2010, Howard Butler wrote:
> Roger,
> I would suggest at least investigating libspatialindex, which is an R*
> tree (and linear and quadratic splitting as well) implementation that is
> much more featureful than the unexposed internal indexing of GEOS.  I
> have just added a C API (GDAL or GEOS-style, it's a total rip-off of
> them) to libspatialindex, to allow users to do the basics like insertion
> and querying quite easily.  Additionally, with libspatialindex, you have
> the option of storing your index on disk and bulk loading (pre-sorting
> for much faster insert performance) the index.
> http://trac.gispython.org/spatialindex/wiki
> http://lists.gispython.org/mailman/listinfo/spatialindex
Thanks for the suggestion.
I'm sorry, but I don't see any documentation whatsoever, after
successfully building. So "quite easily" is maybe not my impression, I'm
afraid, coming from C and interfacing with R.
I need GEOS for Touches/Disjoint (topology operations) anyway, so extra
dependencies are not a help, rather the opposite. All I need is to
identify which bounding boxes (envelopes in GEOM-speak) intersect for a
fixed set of objects whose bounding boxes I can compute, and where GEOS is
already present and running.
The underlying motivation is to find contiguous polygon neighbours for
spatial analysis, hoping to avoid doing Touches on n*((n-1)/2) pairs of
polygons by indexing the bounding boxes and querying which of them
intersect which others.
> Howard
> PS, if you are in the Python world, you can use the Shapely (GEOS
> wrapper) and Rtree (libspatialindex wrapper) combination to do all kinds
> of magic quite painlessly.
No, the R world, additional dependencies are not welcome, believe me.
Maybe they provide use examples (all I asked for) ... links?
Roger
> On May 4, 2010, at 8:30 AM, Roger Bivand wrote:
>> Hi,
>> I'm investigating the use of STRtree functions in C API to find candidate GEOS_MULTIPOLYGON or GEOS_POLYGON objects to test for contiguity, with GEOSDisjoint() or GEOSTouches(). I think that I can see how to build the tree with envelopes of the polygon objects, using an int ID number as the inserted item. However, I'm very unsure how:
>> extern void GEOS_DLL GEOSSTRtree_query_r(GEOSContextHandle_t handle,
>>                                         GEOSSTRtree *tree,
>>                                         const GEOSGeometry *g,
>>                                         GEOSQueryCallback callback,
>>                                         void *userdata);
>> should be understood. The first three arguments appear clear, but neither of the remaining two is. userdata out could be a structure with a pre-allocated int array long enough to hold any intersected object IDs, with an int saying how many are present. Does anyone have any use examples of GEOSSTRtree_query in the C API?
>> Grateful for any pointers,
>> Roger
>> Roger Bivand
>> Economic Geography Section, Department of Economics, Norwegian School of
>> Economics and Business Administration, Helleveien 30, N-5045 Bergen,
>> Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
>> e-mail: Roger.Bivand at nhh.no
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
Roger Bivand
