[geos-devel] [GEOS] #343: After applying a buffer over
a multiline the library starts growing in memory usage and hungs
strk
strk at keybit.net
Fri May 14 14:13:15 EDT 2010
On Fri, May 14, 2010 at 09:11:30AM -0700, Martin Davis wrote:
> I'm surprise that PostGIS is so much faster too! Can you supply the
> output, so I can check it against JTS?
> One thing I notice is that the input I'm using has 5615 elements and
> 11502 points.
The input I'm using is this:
http://trac.osgeo.org/geos/attachment/ticket/344/roads_broken_geom.txt.gz
The output I have with it is attached.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
Type: application/x-gunzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20100514/b1715794/out.txt-0001.bin
