[geos-devel] Dimension and Coordinate Sequences
Frank Warmerdam
warmerdam at pobox.com
Mon May 17 11:42:34 EDT 2010
strk wrote:
> On Mon, May 17, 2010 at 11:25:56AM -0400, Frank Warmerdam wrote:
>> Folks,
>> I am creating a GEOS Point from 2D WKB input, then fetching back the
>> CoordinateSequence and interogating it's dimension. I get "3".
>> Looking through the code there does not seem to be a real effort to preserve
>> dimension for coordinate sequences, at least with the
>> CoordinateArraySequence
>> implementation. Is this intentional?
> The interface was added to later make a real effort,
> but none is made at this time indeed.
Strk,
Is this a good time for me to take a crack at implementing dimension
support? I see the dimension potentially makes it as far as the
CoordinateArraySequenceFactory, but that CoordinateArraySequence has
nothing to keep track of it. I could add it as a private member and
ensure it is passed in by the factory.
> When non-empty you could check for IsNan(Z) but when empty you can't tell..
I'm using the C API. Is there a nice portable way to check for NaN in C code?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
