[geos-devel] Dimension and Coordinate Sequences
Paul Ramsey
pramsey at opengeo.org
Mon May 17 12:46:08 EDT 2010
Great, the more victims^H^H^H^H^H^Husers we have, the better!
(Surely Ingres wants M! :)
P
On Mon, May 17, 2010 at 9:39 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Paul Ramsey wrote:
>> This would be an excellent time! :) It is raised about every 2 months
>> on the list, both the oddness of the return value and the fact that we
>> have no M value support.
> strk wrote:
>> Sure, you may try that.
>> Only, I highly dubt any computation will check dimension of input(s)
>> and use that to dimension the output.
> Paul, strk,
> OK, I'm going to make a quick pass to try and implement support for
> differentiating between 2D and 3D dimension of geometries in the default
> CoordinateSequence related classes and ensure that the path from WKB, and
> WKT to GEOS Geometries and back will preserve dimension.
> At this time I'm not going to try and address M, nor to start going into
> the algorithms and making them dimension aware.
> This is driven by the Ingres implementation effort, by the way.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
