[geos-devel] getCoordinateDimension() - ticket 311
Tue May 25 21:27:16 EDT 2010
Martin Davis wrote:
> In JTS Geometry.getDimension() follows the OGC semantics, and returns
> the dimension of the geometry (not the coordinates).
> So this looks like a bug in GEOS.  IMO this should be fixed.
Martin,
I should clarify.  On deeper examination the only getDimension() that
was not returning the geometry dimension was the C API wrapper one.  I'm
not sure why. So the C++ is getDimension() is already right.
I think we will have to change the values returned by the C API getDimension
function to match C++ even though this introduces a modest risk of problems
for applications using the undocumented current behavior.
> Adding a getCoordinateDimension seems like a good idea.  What would this
> return for coordinates which have XYM?  Would it work for empty geometries?
Well, GEOS does not yet have any M support.
> Maybe strk is right, and this should be changed to an enum. Perhaps the
> enum could be defined as
> XY = 2
> XYZ = 3
> XYZM = 4
> XYM = 5 ?
> Or perhaps there is already a convention covering this?
My personal opinion is that the interpretation of the coordinate
dimensions should not be directly mixed into getting the number
of coordinate dimensions.  But I could be wrong headed on this.
Best regards,
