[geos-devel] Re: [GEOS] #383: error occur when buffer
GEOS geos-trac at osgeo.org
Wed Nov 3 05:04:13 EDT 2010
 Reporter:  atubar      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.2.1
Component:  Default     |     Version:  3.2.0
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Print edgeList.size() as first thing on function enter.
 Also, check the callers.
 Finally attach your input as WKT or WKB.
 Chances are your input geometry is just too big...
 Ah, don't forget to try with current development version !
Ticket URL: <http://trac.osgeo.org/geos/ticket/383#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
