[geos-devel] Re: [GEOS] #383: huge memory cost and crash in buffer
Martin Davis
mbdavis at refractions.net
Wed Nov 3 14:05:32 EDT 2010
I just tried the following approach in JTS, and it works fine (and
reasonably fast)
- Extract all line segments from the boundary of the polygonal geometry P
- Buffer each line segment by the positive buffer amount (i.e. 8665)
- Union the segment buffers (using UnaryUnion for speed) giving geometry U
- Compute P.difference(U)
In the case given the answer is the empty geometry, as expected. But
this approach should work for other situations where a non-empty result
occurs.
On 11/3/2010 9:08 AM, Martin Davis wrote:
> I checked out this case in JTS, and it has the same symptoms. The
> problem is due to the combination of:
> - a very complex input geometry
> - a large negative buffer distance, which is the most difficult
> scenario to compute
> If you can run Java 64-bit with lots of memory and have time to wait,
> you might get an answer out. Otherwise I don't see any simple solution
> to this problem. (Actually by manual inspection it looks like the
> buffer output would be the empty geometry for the given buffer
> distance. But this isn't a general solution, obviously)
> Another way that might work is to buffer the linework of the boundary
> of the geometry using a positive buffer distance, and then subtract
> (difference) the result from the original polygon. However, even the
> boundary of this polygon is complex enough that the boundary buffer
> will have to be computed piecewise (i.e. on short sections of the
> boundary) and then merged.
> Martin
>> Reporter: atubar | Owner: geos-devel@…
>> Type: defect | Status: new
>> Priority: major | Milestone: 3.2.1
>> Component: Default | Version: 3.2.0
>> Severity: Unassigned | Keywords:
>> Comment(by atubar):
>> We need to do buffer operation in our program. Often the single
>> geometry
>> is huge, and the shapefile is big and contain many geometry.
>> So what's the best way that you can show us?
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
