[geos-devel] Error building GEOS enabled in GDAL on Solaris
Namrata Sorte namrata.r.sorte at gmail.com
Thu Nov 25 12:27:10 EST 2010
I am facing problem in installing GDAL with GEOS on Solaris. Below are the
steps follwed:
1) Installed GEOS 3.0.0
2) Configure GDAL with following options:
 ./configure  --prefix=/usr/local \
            --with-threads \
            --with-ogr \
            --with-geos=yes \
            --without-libtool \
            --with-libz=internal \
            --with-libtiff=internal \
            --with-geotiff=internal \
            --without-gif \
            --without-pg \
            --without-grass \
            --without-libgrass \
            --without-cfitsio \
            --without-pcraster \
            --without-netcdf \
            --without-png \
            --without-jpeg \
            --without-gif \
            --without-ogdi \
            --without-fme \
            --without-hdf4 \
            --without-hdf5 \
            --without-jasper \
            --without-ecw \
            --without-kakadu \
            --without-mrsid \
            --without-jp2mrsid \
            --without-bsb \
            --without-grib \
            --without-mysql \
            --without-ingres \
            --without-xerces \
            --without-expat \
            --without-odbc \
            --without-curl \
            --without-sqlite3 \
            --without-dwgdirect \
            --without-panorama \
            --without-idb \
            --without-sde \
            --without-perl \
            --without-php \
            --without-ruby \
            --without-python \
            --without-ogpython \
            --with-hide-internal-symbols
3)make
make[1]: Entering directory `/pool1/innovations/gdal-1.7.
1/port'
g++ -g -O2 -fPIC  -Wall  -DOGR_ENABLED -I/pool1/innovations/gdal-1.7.1/port
     -I../frmts/zlib  -DHAVE_LIBZ -c -o cpl_conv.o cpl_conv.cpp
     -I../frmts/zlib  -DHAVE_LIBZ -c -o cpl_error.o cpl_error.cpp
     -I../frmts/zlib  -DHAVE_LIBZ -c -o cpl_string.o cpl_string.cpp
jpeg_set_defaults                   /pool1/innovations/gdal-1.7.1/libgdal.so
jpeg_CreateCompress                 /pool1/innovations/gdal-1.7.1/libgdal.so
jpeg_read_scanlines                 /pool1/innovations/gdal-1.7.1/libgdal.so
jpeg_start_compress                 /pool1/innovations/gdal-1.7.1/libgdal.so
ld: fatal: Symbol referencing errors. No output written to gdalinfo
collect2: ld returned 1 exit status
make[1]: *** [gdalinfo] Error 1
make[1]: Leaving directory `/pool1/innovations/gdal-1.7.1/apps'
make: *** [apps-target] Error 2
I get error here. I am not able to trace the problem! Don't know if GEOS
installed properly because GDAL was installed properly without geos before
but after reinstalled with GEOS it gives error.
Please help me with this issue.
Thanks,
Namrata
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20101125/318a5758/attachment.html
