[geos-devel] [GEOS] #380: Buffer(Geometry,
0) deletes part of the polygon
geos-trac at osgeo.org
Fri Oct 1 10:53:00 EDT 2010
#380: Buffer(Geometry,0) deletes part of the polygon
Reporter: jaapdekker | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone:
Component: Default | Version: 3.2.0
Severity: Unassigned | Keywords:
Using buffer(Geometry,0) to fix wrong polygons is not always working OK
The polygon that I try to fix has a Self-intersection at or near point -70
57
calling
Select AsText(Buffer(MPolyFromText('MULTIPOLYGON(((-66 58,-66 59,-64
58,-65 58,-66 58),(-70 57,-66 57,-66 58,-68 58,-68 57,-70 57)),((-70
58,-70 57,-72 57,-72 59,-71 59,-71 58,-70 58)))'),0));
gives as result
MULTIPOLYGON(((-70 57, -72 57, -72 59, -71 59, -71 58, -70 58, -70 57)),
((-66 58, -66 59, -64 58, -65 58, -66 58)))
it is missing the part
in the output
I'm Using Spatialite version 2.4rc3 wich is using geos version
3.2.2-CAPI-1.6.2
Ticket URL: <http://trac.osgeo.org/geos/ticket/380>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
