[geos-devel] [GEOS] #382: svn:build autogen fails
GEOS geos-trac at osgeo.org
Mon Oct 25 10:41:25 EDT 2010
 Reporter:  jlpoole     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.0.3
 Severity:  Unassigned  |    Keywords:  autogen
 fetched the current high watermark:
  svn checkout http://svn.osgeo.org/geos/trunk geos-svn
 Changed directory into geos-svn.  Ran autogen:
 hermes geos-svn # ./autogen.sh
 * Running /usr/bin/libtoolize (2.2.10)
    OPTIONS = --force --copy
 libtoolize: putting auxiliary files in `.'.
 libtoolize: copying file `./ltmain.sh'
 libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `macros'.
 libtoolize: copying file `macros/libtool.m4'
 libtoolize: copying file `macros/ltoptions.m4'
 libtoolize: copying file `macros/ltsugar.m4'
 libtoolize: copying file `macros/ltversion.m4'
 libtoolize: copying file `macros/lt~obsolete.m4'
 * Running /usr/bin/aclocal (1.11.1)
 * Running /usr/bin/autoheader (2.65)
 * Running /usr/bin/automake (1.11.1)
    OPTIONS = --add-missing --copy -Woverride
 configure.in:389: required file `build/Makefile.in' not found
 configure.in:389: required file `build/msvc80/Makefile.in' not found
 configure.in:389: required file `build/msvc80/geos_c_dll/Makefile.in' not
 found
 configure.in:389: required file `build/msvc80/geos_lib/Makefile.in' not
 found
 configure.in:389: required file `build/msvc80/geos_python/Makefile.in' not
 found
 configure.in:389: required file `build/msvc80/geos_ruby/Makefile.in' not
 found
 configure.in:389: required file `build/msvc80/geos_unit/Makefile.in' not
 found
 configure.in:389: required file `build/msvc80/geos_xmltester/Makefile.in'
 not found
 configure.in:389: required file `build/msvc90/Makefile.in' not found
 configure.in:389: required file `build/msvc90/geos_c_dll/Makefile.in' not
 found
 configure.in:389: required file `build/msvc90/geos_lib/Makefile.in' not
 found
 configure.in:389: required file `build/msvc90/geos_python/Makefile.in' not
 found
 configure.in:389: required file `build/msvc90/geos_ruby/Makefile.in' not
 found
 configure.in:389: required file `build/msvc90/geos_unit/Makefile.in' not
 found
 configure.in:389: required file `build/msvc90/geos_xmltester/Makefile.in'
 not found
 configure.in:389: required file `build/msvc10/Makefile.in' not found
 configure.in:389: required file `build/msvc10/geos_c_dll/Makefile.in' not
 found
 configure.in:389: required file `build/msvc10/geos_lib/Makefile.in' not
 found
 configure.in:389: required file `build/msvc10/geos_unit/Makefile.in' not
 found
 configure.in:389: required file `build/msvc10/geos_xmltester/Makefile.in'
 not found
   Something went wrong, giving up!
 hermes geos-svn #
Ticket URL: <http://trac.osgeo.org/geos/ticket/382>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
