[geos-devel] [GEOS] #434: Invalid (?) buffer output
GEOS geos-trac at osgeo.org
Mon Apr 4 06:57:24 EDT 2011
 Reporter:  yabo        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
 I'm facing a case where a buffer returns an empty polygon while I believe
 it shouldn't.
 I attached a C++ program demonstrating the problem. I tried it against
 geos 3.2.2 and geos-svn r2999.
 The problem is in the negative buffer of a polygon. For a given value it
 works perfectly (image attached) but if in increase this value by one it
 returns an empty polygon which, given the picture, it shouldn't (or I
 believe so at least).
Ticket URL: <http://trac.osgeo.org/geos/ticket/434>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
