[geos-devel] Re: [GEOS] #368: TopologyException on Union of valid geometries [JTS fails too]
GEOS geos-trac at osgeo.org
Fri Apr 29 05:17:59 EDT 2011
 Reporter:  yabo        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:  jtsbug
Comment(by strk):
 I took a look at the geometries.
 Wow, you can't even see the second geometry while looking at the first
 one.
 A.area: 276,625,072
 B.area:       1,264
 The first geometry (A) is a multipoligon, composed by 3 poligons.
 Unioning geometry B with each of the polygons in geometry A succeeds.
Ticket URL: <http://trac.osgeo.org/geos/ticket/368#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
