[geos-devel] A little performance test: NTS VS GEOS
Sandro Santilli
strk at keybit.net
Tue Aug 16 06:16:47 EDT 2011
Thanks Oyvind for the profiling.
Yeah, WKB parser wasn't a priority as main user of the library (PostGIS)
is using direct construction (via Points).
Nonetheless it's annoying to be slower than a .NET thing, so if anyone
is willing to fund a WKB parser speedup improvement I'll be glad to
work on it ;)
--strk;
On Wed, Aug 10, 2011 at 11:52:25AM +0200, Oyvind Idland wrote:
> Hello,
> I did a little performance test just to test GEOS vs NTS. I have made a
> C++/CLI wrapper for .NET, and the tests was
> run using PreparedGeometries in GEOS (NTS does not have this feature yet).
> In all tests i have done, NTS outperformed GEOS in the total summary.
> The reason ? WkbReader. On the pure geometry operations (Overlaps,
> Intersects etc), GEOS is at least twice as
> fast (possibly faster too in some cases). In my case, I do WKB --> Geometry
> on the fly, and the actual conversion
> perfomance is a bit disappointing.
> Below there are two testresult outputs: Both is executed against a dataset
> containing 10721 polygons, where one
> uses a LineString operand, the other a Polygon operand. The result shows the
> operand being used, the time for WKB
> conversion and operand times.
> I believe there are potential here...
> -- Oyvind
> Operand:POLYGON ((538213.275331 6544838.215101, 538312.712452
> 6545313.648834, 538940.409276 6545621.282426, 540152.299185 6545394.441495,
> 540261.058536 6544841.322511, 54
> 0192.695515 6544493.292588, 539574.320921 6544362.781367, 539235.613228
> 6544213.625686, 538617.238634 6544431.144388, 537467.496926 6544201.196046,
> 215101))
> Results from GEOS tester, extent=[MinX=517365, MinY=6530944, MaxX=544938,
> MaxY=6554152 width=27573 , height=23208]
> Feature count: 10721
> Crosses Count: 0
> Intersects Count: 978
> Covers Count: 128
> Contains Count: 850
> Time used for WKB: 824 millis
> Time used for operand: 217 millis
> Total time: 1041 millis
> Results from NTS tester, extent=[MinX=517365, MinY=6530944, MaxX=544938,
> Crosses Count: 0
> Covers Count: 128
> Contains Count: 850
> Time used for WKB: 172 millis
> Time used for operand: 527 millis
> Total time: 699 millis
> Operand:LINESTRING (538616.04842 6542972.503409, 539659.659719
> 6543126.67326, 540134.028491 6543049.588335, 540424.579364 6542883.559264,
> 540673.622969 6542658.234098, 54
> 0976.033062 6542770.896681, 541029.399549 6542978.433019, 541385.176128
> 6542782.7559, 541628.290123 6542338.035176)
> Crosses Count: 54
> Intersects Count: 54
> Covers Count: 0
> Contains Count: 0
> Time used for WKB: 850 millis
> Time used for operand: 110 millis
> Total time: 960 millis
> Crosses Count: 54
> Covers Count: 0
> Contains Count: 0
> Time used for WKB: 174 millis
> Time used for operand: 247 millis
> Total time: 421 millis
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
