[geos-devel] Re: [GEOS] #469: testrunner fail
geos-trac at osgeo.org
Mon Aug 22 17:16:36 EDT 2011
Reporter: aperi2007 | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.1
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Comment(by aperi2007):
finally I found how execute the program :)
This is the result of execution with gdb:
make[3]: `bug234' is up to date.
make[3]: `TestSweepLineSpeed' is up to date.
make[3]: Leaving directory `/home/archivio/postgres/software/geos/geos-
svn/tests/bigtest'
make[2]: Leaving directory `/home/archivio/postgres/software/geos/geos-
svn/tests/bigtest'
Making check in xmltester
make[2]: Entering directory `/home/archivio/postgres/software/geos/geos-
svn/tests/xmltester'
make check-TESTS
make[3]: Entering directory `/home/archivio/postgres/software/geos/geos-
GNU gdb (GDB) Red Hat Enterprise Linux (7.2-48.el6)
Copyright (C) 2010 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /home/archivio/postgres/software/geos/geos-
svn/tests/xmltester/.libs/lt-XMLTester...done.
(gdb) start
Temporary breakpoint 1 at 0x40e290: file XMLTester.cpp, line 1458.
Starting program: /home/archivio/postgres/software/geos/geos-
svn/tests/xmltester/.libs/lt-XMLTester -v --test-valid-output
./tests/testLeaksBig.xml ./tests/split.xml ./tests/hexwkb.xml
./tests/test.xml ./tests/linemerge.xml ./tests/TestIsValid.xml
./tests/robustness.xml ./tests/buffer.xml ./tests/singlesidedbuffer.xml
./tests/ticket/bug176.xml ./tests/ticket/bug188.xml
./tests/ticket/bug244.xml ./tests/ticket/bug275.xml
./tests/ticket/bug350.xml ./tests/ticket/bug356.xml
./tests/ticket/bug358.xml ./tests/ticket/bug360.xml
./tests/ticket/bug366.xml ./tests/ticket/bug392.xml
./tests/ticket/bug398.xml ./tests/ticket/bug434.xml
./tests/general/TestBoundary.xml ./tests/general/TestBuffer.xml
./tests/general/TestBufferMitredJoin.xml ./tests/general/TestCentroid.xml
./tests/general/TestConvexHull.xml ./tests/general/TestConvexHull-big.xml
./tests/general/TestDistance.xml ./tests/general/TestFunctionAAPrec.xml
./tests/general/TestFunctionAA.xml ./tests/general/TestFunctionLAPrec.xml
./tests/general/TestFunctionLA.xml ./tests/general/TestFunctionLLPrec.xml
./tests/general/TestFunctionLL.xml ./tests/general/TestFunctionPA.xml
./tests/general/TestFunctionPLPrec.xml ./tests/general/TestFunctionPL.xml
./tests/general/TestFunctionPP.xml ./tests/general/TestInteriorPoint.xml
./tests/general/TestRectanglePredicate.xml
./tests/general/TestRelateAA.xml ./tests/general/TestRelateLA.xml
./tests/general/TestRelateLL.xml ./tests/general/TestRelatePL.xml
./tests/general/TestRelateAC.xml ./tests/general/TestRelateLC.xml
./tests/general/TestRelatePA.xml ./tests/general/TestRelatePP.xml
./tests/general/TestSimple.xml ./tests/general/TestUnaryUnion.xml
./tests/general/TestValid.xml ./tests/general/TestValid2.xml
./tests/general/TestValid2-big.xml ./tests/general/TestWithinDistance.xml
./tests/stmlf/stmlf-cases-20061020.xml ./tests/stmlf/stmlf-cases-20061020
-invalid-output.xml ./tests/stmlf/stmlf-cases-20070119.xml
./tests/robust/TestRobustOverlayFixed.xml
./tests/robust/TestRobustRelate.xml ./tests/fme.xml
./tests/TestBufferExternal.xml ./tests/TestBufferExternal2.xml
./tests/heisenbugs.xml ./tests/badguy3.xml ./tests/hole_from_shell.xml
./tests/hole_red.xml ./tests/safe/16595.xml ./tests/safe/16596.xml
Temporary breakpoint 1, main (argC=71, argV=0x7fffffffd838)
at XMLTester.cpp:1458
1458 {
Missing separate debuginfos, use: debuginfo-install
glibc-2.12-1.25.el6_1.3.x86_64 libgcc-4.4.5-6.el6.x86_64
libstdc++-4.4.5-6.el6.x86_64
(gdb) libstdc++-4.4.5-6.el6.x86_64
and this is the result of bt command:
#0 main (argC=71, argV=0x7fffffffd838) at XMLTester.cpp:1458
Regards,
Ticket URL: <http://trac.osgeo.org/geos/ticket/469#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
