[geos-devel] xmltester problem - GEOS installation in cygwin
    Gery .
    gamejihou at hotmail.com
    Wed Aug 24 17:39:25 EDT 2011
Dear users,
I'm trying to install the GEOS (http://trac.osgeo.org/geos/)
application in my cygwin, but I'm getting a problem apparently with
the tinyxml.cpp, this is the error message:
Making check in swig
make[1]: Entering directory `/usr/local/geos-3.2.2/swig'
make[2]: Entering directory `/usr/local/geos-3.2.2/swig'
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `/usr/local/geos-3.2.2/swig'
make[1]: Leaving directory `/usr/local/geos-3.2.2/swig'
Making check in tests
make[1]: Entering directory `/usr/local/geos-3.2.2/tests'
Making check in bigtest
make[2]: Entering directory `/usr/local/geos-3.2.2/tests/bigtest'
make  bug234.exe TestSweepLineSpeed.exe
make[3]: Entering directory `/usr/local/geos-3.2.2/tests/bigtest'
make[3]: `bug234.exe' is up to date.
make[3]: `TestSweepLineSpeed.exe' is up to date.
make[3]: Leaving directory `/usr/local/geos-3.2.2/tests/bigtest'
make[2]: Leaving directory `/usr/local/geos-3.2.2/tests/bigtest'
Making check in xmltester
make[2]: Entering directory `/usr/local/geos-3.2.2/tests/xmltester'
g++ -DHAVE_CONFIG_H -I. -I../../source/headers -I../../source/headers/
geos -I../../source/headers -I../../source/io/tinyxml -
DTIXML_USE_STL    -g -O2 -DGEOS_INLINE  -pedantic -Wall -ansi -Wno-
long-long  -ffloat-store -MT tinyxml.o -MD -MP -MF .deps/tinyxml.Tpo -
c -o tinyxml.o `test -f 'tinyxml/tinyxml.cpp' || echo './'`tinyxml/
tinyxml.cpp
tinyxml/tinyxml.cpp: In static member function `static void
TiXmlBase::EncodeString(const std::string&, std::string*)':
tinyxml/tinyxml.cpp:114: error: `snprintf' undeclared (first use this
function)
tinyxml/tinyxml.cpp:114: error: (Each undeclared identifier is
reported only once for each function it appears in.)
tinyxml/tinyxml.cpp: In member function `void
TiXmlElement::SetAttribute(const char*, int)':
tinyxml/tinyxml.cpp:687: error: `snprintf' undeclared (first use this
function)
TiXmlElement::SetDoubleAttribute(const char*, double)':
tinyxml/tinyxml.cpp:709: error: `snprintf' undeclared (first use this
function)
TiXmlAttribute::SetIntValue(int)':
tinyxml/tinyxml.cpp:1258: error: `snprintf' undeclared (first use this
function)
TiXmlAttribute::SetDoubleValue(double)':
tinyxml/tinyxml.cpp:1269: error: `snprintf' undeclared (first use this
function)
make[2]: *** [tinyxml.o] Error 1
make[2]: Leaving directory `/usr/local/geos-3.2.2/tests/xmltester'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/usr/local/geos-3.2.2/tests'
make: *** [check-recursive] Error 1
I have:
CYGWIN_NT-5.1 gery 1.5.25(0.156/4/2) 2008-06-12 19:34 i686 Cygwin
So, please, is there a way to solve this problem without uninstalling
my current cygwin version and upgrading to the current 1.7 version of
Cygwin?
Any hints are very welcome, thanks in advance.
Best regards,
Gery
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20110824/28177b75/attachment.html
