[geos-devel] Re: [GEOS] #495: Empty return from buffer
geos-trac at osgeo.org
Fri Dec 9 05:13:19 EST 2011
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.3.2
Component: Default | Version: 3.3.0
Severity: Unassigned | Resolution: fixed
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
Fixed by commits r3535 (for trunk) and r3537 (3.3 branch).
The testcase was embedded in
tests/xmltester/tests/safe/TestBufferJagged.xml
See also http://trac.osgeo.org/geos/wiki/BufferRobustness
Ticket URL: <http://trac.osgeo.org/geos/ticket/495#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
