[geos-devel] Call for test of the 3.3 branch
Sandro Santilli
strk at keybit.net
Fri Dec 9 05:59:46 EST 2011
I've spent the last couple of weeks hunting buffer robustness
issues and fixing few more bugs in the 3.3 branch.
I'd release a 3.3.2 shortly with the fixes.
Biggest change is in Buffer operation, specifically in handling
of reduced precision buffering in case of a topology exception
raised with the full-precision attempt.
As I also applied a few patch supposedly fixing build on different
architectures I'd like to call for tests of the branch prior to
closing up the release.
Here's a list of bugfixes:
http://trac.osgeo.org/geos/query?status=closed&order=priority&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component&milestone=3.3.2
Still open issues (not sure they'll make it into 3.3.2):
http://trac.osgeo.org/geos/query?status=assigned&status=new&status=reopened&order=priority&col=id&col=summary&col=milestone&col=status&col=type&col=priority&col=component&milestone=3.3.2
Thanks for testing.
--strk;
,------o-.
| __/ | Thank you for PostGIS-2.0 Topology !
| / 2.0 | http://www.pledgebank.com/postgistopology
`-o------'
