[geos-devel] Re: [GEOS] #501: Snap operation: wrong snapping
geos-trac at osgeo.org
Mon Dec 12 03:11:07 EST 2011
Reporter: aperi2007 | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: GEOS Future
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords: jtsfail
Changes (by strk):
* keywords: => jtsfail
* version: 3.3.0 => svn-trunk
* milestone: 3.3.2 => GEOS Future
Comment:
The case also fails with JTS. It's a known limitation of the snapping
code, quoting from the documentation:
* Too much snapping can result in invalid topology
* being created, so the number and location of snapped vertices
* is decided using heuristics to determine when it
* is safe to snap.
Ticket URL: <http://trac.osgeo.org/geos/ticket/501#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
