[geos-devel] Re: [GEOS] #488: TopologyException unioning valid geometries
GEOS geos-trac at osgeo.org
Wed Dec 14 11:43:12 EST 2011
 Reporter:  sky         |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.2
Component:  Default     |     Version:  3.3.1
 Severity:  Unassigned  |    Keywords:
Comment(by sky):
 Replying to [comment:6 strk]:
 > CascadedUnion is exercised by UnaryUnion, see
 source:trunk/tests/xmltester/tests/general/TestUnaryUnionFloating.xml
 Ok, but I don't know the expected result, my tests-cases are too complex,
 what I'm supposed to put inside the <op> tag ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/488#comment:7>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
