[geos-devel] Re: [GEOS] #501: Snap operation: wrong snapping
geos-trac at osgeo.org
Wed Dec 21 03:29:16 EST 2011
Reporter: aperi2007 | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: GEOS Future
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords: jtsfail
Comment(by strk):
I report a schema of the problem described in the bug.
The input (A-B) and the snap points (S1,S2):
A B S2
S1
The figure produced by current algorithm (A-S2-B):
A B S2
S1
The above happens because vertex snapping for B
gives up when finding S1 being == B and later
segment snapping finds S2 first (for some reason)
and thus produces the invalid overstrike.
Note that inverting the order of S1 and S2 in input
fixes the issue:
=# select st_astext(st_snap('LINESTRING(0 0, 10 0)', 'MULTIPOINT(10 0, 11
0)', 2));
st_astext
LINESTRING(0 0,11 0,10 0)
=# select st_astext(st_snap('LINESTRING(0 0, 10 0)', 'MULTIPOINT(11 0, 10
0)', 2));
st_astext
LINESTRING(0 0,10 0,11 0)
Ticket URL: <http://trac.osgeo.org/geos/ticket/501#comment:7>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
