[geos-devel] Re: [GEOS] #356: multilinestring buffer artifacts
GEOS geos-trac at osgeo.org
Fri Feb 25 05:23:58 EST 2011
 Reporter:  aperi2007   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 I've committed an XML test for this case in r3247
 (thanks Andrea for the small dataset!)
 http://trac.osgeo.org/geos/browser/trunk/tests/xmltester/tests/bug356.xml
Ticket URL: <http://trac.osgeo.org/geos/ticket/356#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
