[geos-devel] Re: [GEOS] #336: Create union Fails
geos-trac at osgeo.org
Fri Jan 28 05:21:35 EST 2011
Reporter: PeteS | Owner: geos-devel@…
Type: defect | Status: new
Priority: trivial | Milestone:
Component: Default | Version: 3.2.0
Severity: Unassigned | Keywords:
Comment(by strk):
Nothing wrong I can think of. Try with current SVN version of GEOS, and
also see if you can produce an XML based testcase (see
tests/xmltester/tests/bug275.xml for an example)
Ticket URL: <http://trac.osgeo.org/geos/ticket/336#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
