[geos-devel] [GEOS] #461: geos-3.3.0 build fails on Solaris 10
Sparc - Sun Studio 12.2
geos-trac at osgeo.org
Mon Jul 25 06:38:39 EDT 2011
#461: geos-3.3.0 build fails on Solaris 10 Sparc - Sun Studio 12.2
Reporter: sandy2010 | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.3.1
Component: Default | Version: 3.3.0
Severity: Significant | Keywords: SunOS, Solaris 10,
I'm building geos-3.3.0 on Solaris 10 64bit Sparc zone and got the
following error:
make[4]: Entering directory `/opt/geos-3.3.0/src/algorithm/locate'
source='IndexedPointInAreaLocator.cpp'
object='IndexedPointInAreaLocator.lo' libtool=yes \
DEPDIR=.deps depmode=none /bin/bash ../../../depcomp \
/bin/bash ../../../libtool --tag=CXX --mode=compile CC -m64 -KPIC
-DHAVE_CONFIG_H -I. -I../../../include -I../../../include/geos
-I../../../include -pedantic -library=stlport4 -library=Crun -c -o
IndexedPointInAreaLocator.lo IndexedPointInAreaLocator.cpp
libtool: compile: CC -m64 -KPIC -DHAVE_CONFIG_H -I. -I../../../include
-I../../../include/geos -I../../../include -pedantic -library=stlport4
-library=Crun -c IndexedPointInAreaLocator.cpp -KPIC -DPIC -o
.libs/IndexedPointInAreaLocator.o
CC: Warning: Option -pedantic passed to ld, if ld is invoked, ignored
otherwise
"../../../include/geos/platform.h", line 107: Error: #error "Can not
compile without isnan function or macro".
make[4]: *** [IndexedPointInAreaLocator.lo] Error 1
make[4]: Leaving directory `/opt/geos-3.3.0/src/algorithm/locate'
I'm using SunStudip 12.2 and my configure switches looks like this:
./configure --prefix=/opt/geos-3.3.0/inst --disable-inline
CXXFLAGS="-library=stlport4 -library=Crun" LDFLAGS="-lm -m64"
Is there a patch available to this?
Ticket URL: <http://trac.osgeo.org/geos/ticket/461>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
