[geos-devel] Re: [GEOS] #299: geos::geom::CoordinateArraySequenceFactory unit test failing
GEOS geos-trac at osgeo.org
Sun Jul 31 13:23:34 EDT 2011
 Reporter:  pramsey         |        Owner:  geos-devel@…
     Type:  defect          |       Status:  new
 Priority:  major           |    Milestone:  GEOS Future
Component:  Unit Tests      |      Version:  svn-trunk
 Severity:  Unassigned      |   Resolution:
 Keywords:  mac,macosx,osx  |
Comment(by kyngchaos):
 Well, gcc-4.0 seems to be working.  '''BUT.'''
 In OS X 10.7 Lion/Xcode 4.1 Apple dropped gcc-4.0!  Probably goes along
 with dropping the 10.5 SDK (10.5 used gcc 4.0).
 Maybe I'll have better luck with the now-default llvm, if I can get it to
 work.
Ticket URL: <http://trac.osgeo.org/geos/ticket/299#comment:24>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
