[geos-devel] [GEOS] #447: Can't compile GEOS 3.3 under mingw-64
geos-trac at osgeo.org
Wed Jun 1 15:01:44 EDT 2011
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
We've been trying to get GEOS 3.3.0 to compile udner my mingw-64 on a
Windows 2008 64-bit box. I get the same issue using the mingw-64/32 bit
version and with several different builds as well.
I have been successful compiling PostgreSQL under mingw-64, but to I know
Andrew Dunstan went thru a great deal of pain making this possible. I
fear the road to glory may be paved with rocks.
Of course this is all so I can get PostGIS to run under 64-bit PostgreSQL.
BTW now that geos 3.3.0 is now released, don't you think you should add
it to the version list.
I have attached our build log and configure log. for reference this is
the mingw64 build we are using --
http://sourceforge.net/projects/mingw-w64/files/Toolchains%20targetting%20Win64/Personal%20Builds/sezero_20110510/
mingw-w64-bin_x86_64-mingw_20110510_sezero.zip
Ticket URL: <http://trac.osgeo.org/geos/ticket/447>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
