[geos-devel] Re: [GEOS] #447: Can't compile GEOS 3.3 under mingw-64
GEOS geos-trac at osgeo.org
Wed Jun 1 16:14:52 EDT 2011
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.3.0
 Severity:  Unassigned  |    Keywords:
Comment(by mloskot):
 There is no need for CMake 64-bit to build software using 64-bit
 toolchain.
 CMake is just an executor, it can run nearly any compiler it can find in
 the system.
Ticket URL: <http://trac.osgeo.org/geos/ticket/447#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
