[geos-devel] compiling 3.3.0 on 64-bit RHEL 6
John Cartwright
John.C.Cartwright at noaa.gov
Wed Jun 22 12:19:21 EDT 2011
Hello All,
I'm getting an XMLTester error during "make check" after a successful
compile (see below). Platform is 64-bit RHEL 6.1. No options provided
to configure. Any ideas as to the problem? Does this test failure
suggest a severity that would prevent me from using the library?
Thanks!
--john
Making check in xmltester
make[2]: Entering directory
`/data/backup/contrib/src/geos-3.3.0/tests/xmltester'
make check-TESTS
make[3]: Entering directory
Runner: testrunner created
lt-XMLTester: GeometryComponentFilter.cpp:35: virtual void
geos::geom::GeometryComponentFilter::filter_ro(const
geos::geom::Geometry*): Assertion `0' failed.
./testrunner: line 2: 13547 Aborted (core dumped)
./XMLTester -v --test-valid-output ./tests/testLeaksBig.xml
./tests/split.xml ./tests/hexwkb.xml ./tests/test.xml
./tests/linemerge.xml ./tests/TestIsValid.xml ./tests/robustness.xml
./tests/buffer.xml ./tests/singlesidedbuffer.xml
./tests/ticket/bug176.xml ./tests/ticket/bug188.xml
./tests/ticket/bug244.xml ./tests/ticket/bug275.xml
./tests/ticket/bug350.xml ./tests/ticket/bug356.xml
./tests/ticket/bug358.xml ./tests/ticket/bug360.xml
./tests/ticket/bug366.xml ./tests/ticket/bug392.xml
./tests/ticket/bug398.xml ./tests/ticket/bug434.xml
./tests/general/TestBoundary.xml ./tests/general/TestBuffer.xml
./tests/general/TestBufferMitredJoin.xml
./tests/general/TestCentroid.xml ./tests/general/TestConvexHull.xml
./tests/general/TestConvexHull-big.xml ./tests/general/TestDistance.xml
./tests/general/TestFunctionAAPrec.xml
./tests/general/TestFunctionAA.xml
./tests/general/TestFunctionLAPrec.xml
./tests/general/TestFunctionLA.xml
./tests/general/TestFunctionLLPrec.xml
./tests/general/TestFunctionLL.xml ./tests/general/TestFunctionPA.xml
./tests/general/TestFunctionPLPrec.xml
./tests/general/TestFunctionPL.xml ./tests/general/TestFunctionPP.xml
./tests/general/TestInteriorPoint.xml
./tests/general/TestRectanglePredicate.xml
./tests/general/TestRelateAA.xml ./tests/general/TestRelateLA.xml
./tests/general/TestRelateLL.xml ./tests/general/TestRelatePL.xml
./tests/general/TestRelateAC.xml ./tests/general/TestRelateLC.xml
./tests/general/TestRelatePA.xml ./tests/general/TestRelatePP.xml
./tests/general/TestSimple.xml ./tests/general/TestUnaryUnion.xml
./tests/general/TestValid.xml ./tests/general/TestValid2.xml
./tests/general/TestValid2-big.xml
./tests/general/TestWithinDistance.xml
./tests/stmlf/stmlf-cases-20061020.xml
./tests/stmlf/stmlf-cases-20061020-invalid-output.xml
./tests/stmlf/stmlf-cases-20070119.xml
./tests/robust/TestRobustOverlayFixed.xml
./tests/robust/TestRobustRelate.xml ./tests/fme.xml
./tests/TestBufferExternal.xml ./tests/TestBufferExternal2.xml
./tests/heisenbugs.xml ./tests/badguy3.xml ./tests/hole_from_shell.xml
./tests/hole_red.xml ./tests/safe/16595.xml ./tests/safe/16596.xml
FAIL: testrunner
1 of 1 test failed
make[3]: *** [check-TESTS] Error 1
make[3]: Leaving directory
make[2]: *** [check-am] Error 2
make[2]: Leaving directory
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/data/backup/contrib/src/geos-3.3.0/tests'
make: *** [check-recursive] Error 1
