[geos-devel] Re: [GEOS] #397: Valgrind reported errors with -O0
(was: Conditional jump or move depends on uninitialised value(s))
geos-trac at osgeo.org
Tue Mar 1 11:26:07 EST 2011
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Changes (by strk):
* version: 3.0.3 => svn-trunk
Comment:
Seems to only happen when building with -O0.
The previous report was on a 64bit system, on a 32bit (with -O0) it's even
worst:
==21569== Invalid read of size 4
==21569== at 0x41544F6:
geos::algorithm::LineIntersector::intersection(geos::geom::Coordinate
const&, geos::geom::Coordinate const&, geos::geom::Coordinate const&,
geos::geom::Coordinate const&, geos::geom::Coordinate&) const (in
/usr/src/geos/build-O0/src/.libs/libgeos-3.3.0.so)
==21569== by 0x4153831:
geos::algorithm::LineIntersector::computeIntersect(geos::geom::Coordinate
geos::geom::Coordinate const&) (in
==21569== by 0x41526F6:
geos::algorithm::LineIntersector::computeIntersection(geos::geom::Coordinate
==21569== by 0x41A7FA8:
geos::geomgraph::index::SegmentIntersector::addIntersections(geos::geomgraph::Edge*,
int, geos::geomgraph::Edge*, int) (in
==21569== by 0x41AC9B6:
geos::geomgraph::index::MonotoneChainEdge::computeIntersectsForChain(int,
int, geos::geomgraph::index::MonotoneChainEdge const&, int, int,
geos::geomgraph::index::SegmentIntersector&) (in
==21569== by 0x41ACB4C:
==21569== by 0x41AC94E:
==21569== by 0x41ABD88:
geos::geomgraph::index::MonotoneChain::computeIntersections(geos::geomgraph::index::MonotoneChain*,
geos::geomgraph::index::SegmentIntersector*) (in
==21569== by 0x41ABB7B:
geos::geomgraph::index::SimpleMCSweepLineIntersector::processOverlaps(int,
int, geos::geomgraph::index::SweepLineEvent*,
==21569== by 0x41ABAC7:
geos::geomgraph::index::SimpleMCSweepLineIntersector::computeIntersections(geos::geomgraph::index::SegmentIntersector*)
(in /usr/src/geos/build-O0/src/.libs/libgeos-3.3.0.so)
==21569== by 0x41AB6C9:
geos::geomgraph::index::SimpleMCSweepLineIntersector::computeIntersections(std::vector<geos::geomgraph::Edge*,
std::allocator<geos::geomgraph::Edge*> >*,
std::vector<geos::geomgraph::Edge*, std::allocator<geos::geomgraph::Edge*>
>*, geos::geomgraph::index::SegmentIntersector*) (in
==21569== Address 0xbec49f68 is just below the stack ptr. To suppress,
use: --workaround-gcc296-bugs=yes
==21569==
Ticket URL: <http://trac.osgeo.org/geos/ticket/397#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
