[geos-devel] Calling MinimumDiameter from C API
jiajianying jiajianying at tigerknows.com
Fri Mar 4 01:13:41 EST 2011
On 2011年03月03日 20:29, Sandro Santilli wrote:
> On Thu, Mar 03, 2011 at 04:28:09PM +0800, jiajianying wrote:
>> How to extend C api? Edit the source file and submit to trunk? Is there
>> any developer's guide?
> Here's the guide:
> 1. Open geos_ts_c.cpp
> 2. Copy an existin function that "looks like" the one you're goin to make
> 3. Adapt to your case
> 4. Write a wrapper in geos_c.cpp (same thing: copy an existing one)
> 5. Write signature in geos_c.h.in
> 6. Send patch
> Finally: use the mailing list for any further communications :)
> --strk;
>    ()   Free GIS&  Flash consultant/developer
>    /\   http://strk.keybit.net/services.html
How long will the update be part of GEOS package(release/trunk)? In
other words, I don't want to copy source files and rebuild GEOS when my
application is installed on other machines.
By the way, patches are sent with the trac system?
Justin
