[geos-devel] Re: [GEOS] #353: LinearReferencing functions segfaults
geos-trac at osgeo.org
Mon May 9 16:24:01 EDT 2011
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.2.3
Component: Default | Version: 3.2.2
Severity: Unassigned | Keywords:
Changes (by strk):
* version: 3.2.0 => 3.2.2
* milestone: 3.2.1 => 3.2.3
Old description:
> When calling GEOSInterpolate against a POINT geometry (C-API), a segfault
> happens. See #283 for when that code was added.
> NOTE: milestone should be 3.2.3 but doesn't exist.
> Also, versions 3.2.1 and 3.2.2 should be added to trac.
> Also, r3012, r3013, r3014 and r3015 should be back-ported to 2.x branch.
New description:
Also, r3012, r3013, r3014 and r3015 should be back-ported to 3.2 branch.
Ticket URL: <http://trac.osgeo.org/geos/ticket/353#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
