[geos-devel] Re: [GEOS] #440: xmltester failures under MingW 32 bit
GEOS geos-trac at osgeo.org
Wed May 25 15:49:29 EDT 2011
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:  mingw
Comment(by strk):
 Could you also check:
 grep CXXFLAGS Makefile
 I want to make sure -O2 is used. Also, which compiler version ?
 Both failing tests are very sensible to numeric robustness issues...
Ticket URL: <http://trac.osgeo.org/geos/ticket/440#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
