[geos-devel] Re: [GEOS] #440: xmltester failures under MingW 32 bit
geos-trac at osgeo.org
Fri May 27 03:09:05 EDT 2011
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords: mingw
Comment(by robe):
Just for extra information:
I'm running:
gcc version 3.4.5 (mingw-vista special r3
I'll try a newer one once I remember how I toggled back and forth between
the 2 gccs before.
Ticket URL: <http://trac.osgeo.org/geos/ticket/440#comment:8>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
