[geos-devel] Re: [GEOS] #299:
geos::geom::CoordinateArraySequenceFactory unit test failing
geos-trac at osgeo.org
Tue Oct 4 17:35:28 EDT 2011
#299: geos::geom::CoordinateArraySequenceFactory unit test failing
Reporter: pramsey | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: GEOS Future
Component: Unit Tests | Version: svn-trunk
Severity: Unassigned | Resolution:
Keywords: mac,macosx,osx |
Description changed by strk:
Old description:
> ---> group: geos::geom::CoordinateArraySequenceFactory, test: test<1>
> problem: assertion failed
> The problem goes away when I comment out lines 55 and 56 of the test.
> :trac:browser/trunk/tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp#L55
> Problem seen on OS/X 10.6, i686-apple-darwin10-gcc-4.2.1
New description:
source:trunk/tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp#L55
Ticket URL: <http://trac.osgeo.org/geos/ticket/299#comment:26>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
