[geos-devel] Problems with BufferOp when using BufferParameters
Sandro Santilli
strk at keybit.net
Wed Oct 26 08:12:55 EDT 2011
On Wed, Oct 26, 2011 at 12:14:59PM +0200, Markus Meyer wrote:
> // Working code
> geos::geom::Polygon* pPolygon = dynamic_cast<geos::geom::Polygon*>(
> geos::operation::buffer::BufferOp::bufferOp(
> pLineString, fOffset, 16,
> geos::operation::buffer::BufferParameters::CAP_ROUND));
> When I do the buffering by using the BufferOp and BufferParameters
> class directly, the resulted geometry looks very strange:
> // Not working code
> geos::operation::buffer::BufferParameters params(
> 16,
> geos::operation::buffer::BufferParameters::CAP_ROUND);
> geos::operation::buffer::BufferOp op(pLineString, params);
> dynamic_cast<geos::geom::Polygon*>(op.getResultGeometry(fOffset));
> From my understanding, the results of both code snipets should be the same.
You're right. They should.
Could you file a ticket for this on http://trac.osgeo.org/geos ?
Also try the attached patch (attach it to the ticket if it works).
Thanks !
Note: you shouldn't be using the C++ interface :)
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20111026/7b07cdd3/alias.bin
