[geos-devel] Problems with BufferOp when using BufferParameters
Markus Meyer
meyer at mesw.de
Fri Oct 28 05:39:43 EDT 2011
Mateusz,
thanks for creating the test.
Here are information about the used coordinates and the used offset
(dumped from the code):
Coordinate #0 = 0.0, 0.0
Coordinate #1 = 100.0, 0.0
Coordinate #2 = 100.0, 100.0
Coordinate #3 = 0.0, 100.0
Coordinate #4 = 0.0, 0.0
fOffset = 5.00
Is there any chance that this problem is being fixed soon? I reviewed
the code myself already but so far I could not easily find the problem
so I would really need to debug into the code which might be rather
time-consuming. So I would really appreciate if someone who is familiar
with the inner concepts of GEOS could have a quick look at the problem,
especially as now there is a test case for it.
Best regards,
Markus
Am 26.10.2011 20:56, schrieb Mateusz Łoskot:
> On 26 October 2011 11:14, Markus Meyer<meyer at mesw.de> wrote:
>> I'm using GEOS 3.3.0 on Microsoft Visual Studio 2008 (Windows 7) for
>> buffering lines using BufferOp.
>> I would like to use the BufferParameters class to control extended
>> parameters. However, it seems that I must be using the BufferOp class the
>> wrong way because my parameters are never accepted. To explain this, I
>> created a simple test program which offsets a rectangle.
>> When I do the buffering with the static function Buffer::bufferOp() the
>> resulting geometry looks OK:
>> // Working code
>> geos::geom::Polygon* pPolygon = dynamic_cast<geos::geom::Polygon*>(
>> geos::operation::buffer::BufferOp::bufferOp(
>> pLineString, fOffset, 16,
>> geos::operation::buffer::BufferParameters::CAP_ROUND));
>> When I do the buffering by using the BufferOp and BufferParameters class
>> directly, the resulted geometry looks very strange:
>> // Not working code
>> geos::operation::buffer::BufferParameters params(
>> 16,
>> geos::operation::buffer::BufferParameters::CAP_ROUND);
>> geos::operation::buffer::BufferOp op(pLineString, params);
>> dynamic_cast<geos::geom::Polygon*>(op.getResultGeometry(fOffset));
>> From my understanding, the results of both code snipets should be the same.
> Markus,
> As Sandro confirmed, both ways should produce the same results.
> I have added test case that tries to reproduce your use case.
> Here it is:
> http://trac.osgeo.org/geos/changeset/3509
> It is based on one of test geometries used across the GEOS unit tests.
> If you can provide your geometry, it would be helpful.
> Then we could replace the WKT input in the test and have it covered.
> Best regards,
