[geos-devel] [GEOS] #472: Can't compile under Windows mingw
geos-trac at osgeo.org
Sun Sep 4 01:56:16 EDT 2011
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.4.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Can't remember the last time I tried. I can still compile 3.3 branch
okay.
I tried compiling r3463 and get below error:
XMLTester-SingleSidedBufferResultMatcher.o: In function
`ZN4geos9xmltester30Sing
leSidedBufferResultMatcher38isBoundaryHausdorffDistanceInToleranceERKNS_4geom8Ge
ometryES5_d':
C:/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/c++/3.4.5/bits/stl_uni
nitialized.h:1058: undefined reference to
`geos::geom::Coordinate::~Coordinate() '
ometryES5_d':
C:/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/c++/3.4.5/bits/stl_con
struct.h:107: undefined reference to
`geos::geom::Coordinate::~Coordinate()'
collect2: ld returned 1 exit status
make[2]: *** [XMLTester.exe] Error 1
make[2]: Leaving directory `/c/projects/geos/trunk/tests/xmltester'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/c/projects/geos/trunk/tests'
make: *** [all-recursive] Error 1
Ticket URL: <http://trac.osgeo.org/geos/ticket/472>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
