[geos-devel] Re: [GEOS] #447: Can't compile GEOS 3.3 under mingw-64
GEOS geos-trac at osgeo.org
Tue Sep 27 11:15:19 EDT 2011
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.1
Component:  Default     |     Version:  3.3.0
 Severity:  Unassigned  |    Keywords:
Comment(by robe):
 strk -- it still doesn't work.  I guess you can push it to 3.3.2 once you
 create that milestone since it probably won't be fixed anytime soon.  My
 next attempt is to try to building using cmake but having issue compiling
 cmake under mingw64 which I have to workout.
Ticket URL: <http://trac.osgeo.org/geos/ticket/447#comment:7>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
