[geos-devel] Re: [GEOS] #527: Union and UnaryUnion both fail at correctly node input lines
GEOS geos-trac at osgeo.org
Mon Apr 2 08:45:03 EDT 2012
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.4
Component:  Default     |     Version:  3.3.3
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 I've attached the script defining an SQL function to check for correct
 noding here:
 http://trac.osgeo.org/postgis/attachment/ticket/1735/CheckNoding.sql
Ticket URL: <http://trac.osgeo.org/geos/ticket/527#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
