[geos-devel] Re: [GEOS] #527: Union and UnaryUnion both fail at
 correctly node input lines
    geos-trac at osgeo.org
    Mon Apr  2 09:32:23 EDT 2012
#527: Union and UnaryUnion both fail at correctly node input lines
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.4
Component:  Default     |     Version:  3.3.3
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Ah, I see the EdgeNodingValidator runs _before_ we re-add the common bits
 that we removed before runnign the operation. I bet the re-addition of
 commit bits is introducing more non-noded intersection. It would not be
 the first time I detect such behavior. I start thinking that removing
 common bits heuristic isn't such a good one.
Ticket URL: <http://trac.osgeo.org/geos/ticket/527#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
