[geos-devel] [GEOS] #605: Crash from GEOSBuffer: RightmostEdgeFinder.cpp: Assertion `checked>0` failed
geos-trac at osgeo.org
Tue Dec 4 04:42:41 PST 2012
failed
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.3.7
Component: Default | Version: 3.3.6
Severity: Critical | Keywords:
Comment(by strk):
In any case the assertion means that there are NO forward edges in a
BufferSubgraph, which is probably a robustness issue on its own (so may be
worth a TopologyException).
What do you think Martin ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/605#comment:8>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
