[geos-devel] [GEOS] #605: Crash from GEOSBuffer: RightmostEdgeFinder.cpp: Assertion `checked>0` failed
GEOS geos-trac at osgeo.org
Tue Dec 4 02:59:20 PST 2012
failed
 Reporter:  strk      |       Owner:  geos-devel@…
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  3.3.7
Component:  Default   |     Version:  3.3.6
 Severity:  Critical  |    Keywords:
Comment(by strk):
 Attempts to buffer with original precision fail with this:
 TopologyException: assigned depths do not match at 366818.60878326674
 6133401.6729513798
 Then GEOS enters the precision reduction loop, starts with scaleFactor
 100000 and reduces scale factor by 10 on every iteration. Every iteration
 fails with a similar TopologyException.
 The last one before the crash is with scaleFactor=1:
 TopologyException: assigned depths do not match at 364550 6129605
 When trying scale factor = 0.1 we get the crash.
 I'm surprised that scale factor of 10 shows more than a single decimal
 digit in the topology exception:
 TopologyException: assigned depths do not match at 364818.32000000001
 6129887.71
Ticket URL: <http://trac.osgeo.org/geos/ticket/605#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
