[geos-devel] [GEOS] #608: IsValidOp should return eNestedShells not eNestedHoles at ln 530
GEOS geos-trac at osgeo.org
Mon Dec 24 15:22:38 PST 2012
 Reporter:  geomworx    |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  minor       |   Milestone:  3.3.7
Component:  Default     |     Version:  3.3.6
 Severity:  Unassigned  |    Keywords:
 Stepping through code, I believe that inside
 3rd_geos\IsValidOp.cpp::checkShellNotNested(), on line 530, the keyword:
   eNestedHoles
 should be replaced by:
   eNestedShells
 Since the error detected here is shells being nested, not holes being
 nested.
Ticket URL: <http://trac.osgeo.org/geos/ticket/608>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
